Our dryer that is almost two years old has stopped working. It doesn't appear to be getting power. We've tested the outlet and it is live. Just as a double check, we've reset the circuit breaker although since the outlet is getting power, that isn't the cause. Is there a reset on the dryer? The dryer has barely been used. It is located in a condo that is only used for visiting an elderly relative and for short vacations. Any troubleshooting help would be appreciated prior to us calling for a repair tech. Thanks!
