rockerjim
#1 Posted : Wednesday, May 13, 2009 7:06:52 AM(UTC)
rockerjim
I have a Whirlpool Quiet Partner II dishwasher that stops and start by itself. If I start machine before going to bed it will still be running in the morning. It will be starting and stoping every few minutes. Could this be a problem with the latch. This problem seemed to start with the anti-bacterial cycle, now it does this on every cycle
#2 Posted : Thursday, May 14, 2009 2:41:28 AM(UTC)
Need more info. Is it stuck on one cycle like wash? Will it accept keypad entries? Also, check your water temperature, should be above 120 degrees.
rockerjim
#3 Posted : Thursday, May 14, 2009 3:14:41 AM(UTC)
rockerjim
Eventually machine will complete the full wash cycle. Water is hot. the key pad seems to work fine.
Thanks for your reply
Jim
#4 Posted : Thursday, May 14, 2009 5:26:15 AM(UTC)
I would measure the temperature and verify over 120 degrees.
rockerjim
#5 Posted : Thursday, May 14, 2009 11:11:54 AM(UTC)
rockerjim
I checked the water temp. During the wash cycle water is not 120 degrees. During the rinse cycle water is at 140 degrees. Look forward to your advise
Jim
#6 Posted : Thursday, May 14, 2009 3:03:51 PM(UTC)
I would check the heater and thermostat, the computer might be trying to bring the water temperature up and failing to do this it runs longer than normal.
