Changed igniter. Works ok. Just noticed a pop last time we turned it on. Gas build up? Worked fine after that. But that is not a good thing. What do I look for? Afraid to open it start it and stick my head in there.
I opened it up. Igniter arm was bent out a little. I moved it in closer and reluctantly tried it again. Looked to work ok with door open and me standing back. Could it have been that the igniter was a little too far away from gas arm?
