Here is the model number: J KP45BOA1BB
It is a wall installed double oven.
Groups: APP Team
Hi.
You have a different control board it's WB27T10282. What it the original problem. Please be more detailed.
Simon.
Yes. I have procrastinated for a year but I finally determined the control panel is bad for oven #1. No voltage out of BAKE 1. So I ordered the recommended part in this thread. Only upon inspection, i have a problem, the old control panel is part #wb27t10055 has been replaced with the new control panel part #wb27t10283, which is the part suggested here and confirmed by GE. Only the connections are slightly different. I am an electrical engineer and am comfortable making connector mondifications, but I cannot find any wiring diagrams to show me how.
I have a GE true temp gas oven. The broil works but when I try to bake only the fan comes on. I cant even see the igniter coming on . The model number is JGSP28SEK4SS
