whirlpool electric downdraft ceramic glass cooktop - dual burner not working properly, element is full on regardless of setting - will turn off - inner emement working proplerly
The correct model number is: GJD3644LB01
The infinite switch pointsl may have arced together. See if you can remove and disassemble the burner switch to confirm. There may be two set of points and the inner coil is still working.
