2 Pages<12
loma
#11 Posted : Tuesday, January 13, 2009 3:42:10 PM(UTC)
loma
It does not work with the FloodSafe valve....not sure why. Try regular hoses - mine worked fine with regular hoses.
docrings
#12 Posted : Wednesday, November 19, 2014 6:39:55 PM(UTC)
docrings
One thing I found out is to check the hot water hose valve behind the washer... if it was shut off by someone, the washer will stop filling after a few seconds if a warm or hot wash remp was selected.
Sometimes, someone in the house shuts off the hoses, but only turns on the cold later.
Worth a thought.
Cheers,
Doc
:cool:
2 Pages<12
