dansally
#1 Posted : Sunday, November 16, 2014 9:57:16 AM(UTC)
dansally
I have had to replace the Thermal Fuse three times in the past few months. I am hoping someone can tell me what to look at to determine the underlying cause. Here is the info on the fuse in case you need it:
SKU: SUP3392519
Description: FUSE ET401 SET401 ER3392519 QP
Thanks in advance!
Dan
#2 Posted : Monday, November 17, 2014 2:49:15 AM(UTC)
Views messages in topic : 19,638
Parts for Maytag MED5840TW0 Dryer - AppliancePartsPros.com
The most common cause of this fuse blowing is a vent problem.
Check/clean your vent system.
Check that the louvers on the vent outside the house open fully.
