gr8filed
#1 Posted : Tuesday, September 23, 2014 5:00:41 PM(UTC)
gr8filed
I have a lg dishwasher that defaults to a 2 hr delay start every time we use it. If you clear the screen and try to start again it will put a 2 hr delay start on the screen. The buttons do not feel stuck. If i press the delay button the numbers will change. Any ideas ?
22bob
#2 Posted : Sunday, November 16, 2014 7:19:36 AM(UTC)
22bob
It's so simple it's Stupid! Been driving us crazy for 4 months!
First press and hold the two buttons all the way to the right (cancel).
Then simply select your wash cycle (Normal, etc.)
Here's the trick, ignore the number in the display.... It is Not the Timer amount it is only an estimate of how long the selected wash cycle will take.
(If you press the various cycles you'll see the display change).
It's confusing because you think that the Number is for the timer.
Then you press the timer button trying to clear it and what is really happening is that you just inadvertanly set the timer!
gr8filed
#3 Posted : Tuesday, November 18, 2014 4:10:48 PM(UTC)
gr8filed
thanks, so simple but you were correct
gr8filed
#4 Posted : Tuesday, November 18, 2014 4:12:02 PM(UTC)
gr8filed
thanks, so simple
