My Dishwasher W/n Work. So I Unplugged & Replugged The Pwr. Cord From The 120v Outlet To Reset It. And This Is The Action I Got:the Normal & Rinse Cycle Button Green Lights Come Steady. The No. 2 Illuminates In The Time Remaining Window & I Can Here The Drain Pump Working For A Short While Then It Stops.then The Time Remaining Window Changes To Two Green Dashes That Remain On Steady. When I Press All The Other Cycle & Option Buttons I Get No Green Lights & Nothing Happens. I Do Notice When I Press The Anti-bacterial & Pots/pans Buttons They Do Not Have A Spring-back Feel To Them Like The Others. Also If I Press (the Quick Wash Button) The Normal & Rinse Button Green Lights Start To Flash. Please Advise! Thank You Very Much!
