AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't agitate or spin, can turn motor by hand
Hi I have exactly the same problem as you. I do not understand how you performed the test which lead you to the faulty switch. Do I have to disconnect the black cable from the motor and connect there the red cable coming from the capacitor?
Did you ever get this resolved? I have the same issue.
washer won't agitate or spin and buzzing sound and found a 2 inch metal pin with hole in the end and flat on 1 side..
Originally Posted by: irishfan327 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) washer won't agitate or spin and buzzing sound and found a 2 inch metal pin with hole in the end and flat on 1 side.. hi where is my answer please
Washer Repair
