pctechtv
#1 Posted : Wednesday, November 12, 2014 6:09:59 AM(UTC)
pctechtv
Hi, washer will start it seem to go through first cycle and then it just struggles to spin and never seems to drain. Thanks
sidfink43
#2 Posted : Thursday, November 13, 2014 4:53:48 AM(UTC)
sidfink43
You have been a member since:: 3/29/2009(UTC)
The first thing you want to check is the pump, it might be jammed in a way that allows it to turn only in one direction. Then check the coupling.
If these are not the problem the transmission may be an issue. When you take off the motor to check the coupling use the plastic piece on the transmission shaft that connects to the couple to see if it turns to spin the tub.
There are videos on this site that will show you how to open it up if you need them.
