steve5024
#1 Posted : Saturday, November 8, 2014 8:57:28 AM(UTC)
steve5024
replaced ignitor flame sensor has continuity as does thero fuse. has no glow at ignitor. Im baffled
thorning
#2 Posted : Tuesday, November 11, 2014 4:49:57 AM(UTC)
thorning
Which fuse are you referring to in your comment ? You might try using a jumper wire and temporarily bypassing the various thermostats and fuses one at a time. Also is the drum turning OK ? Is the vent clear and the blower putting out a good flow of air. These are the most trouble prone areas in dryers.
maytag gas dryer no heat (Dryer Repair)
by kingstos 1/20/2012 5:58:33 AM(UTC)
