TheDude
#1 Posted : Saturday, November 8, 2014 8:16:14 AM(UTC)
TheDude
On both cycles (Normal & Permanent Press), the washer doesn't rinse; stops just before it, and makes a buzzing sound (very low volume). I try to restart it just to rinse. No luck. I have to just rewash the load with no detergent to rinse.
UserPostedImage
fairbank56
#2 Posted : Saturday, November 8, 2014 1:53:02 PM(UTC)
fairbank56
Groups: Expert
So, after spin stops, it won't fill for rinse? Rinse cycle is cold water only. The buzzing is probably the cold water valve solenoid. If you set temp to Cold/Cold (non-ATC), do you get cold water during wash fill?
Eric
Older Bosch Dishwasher Doesn't Rinse Properly (Dishwasher Repair)
by bamc 2/5/2011 7:08:32 PM(UTC)
