The control panel on my Dacor CPS230 is malfunctioning. The up (time.temp) arrow on the controls seems to be broken. I can turn the oven on to 350, but can't easily get it to go higher. At times I can repeatedly press the up arrow and get a small increase. The panel does not display any error codes.
Originally Posted by: mcorina  The control panel on my Dacor CPS230 is malfunctioning. The up (time.temp) arrow on the controls seems to be broken. I can turn the oven on to 350, but can't easily get it to go higher. At times I can repeatedly press the up arrow and get a small increase. The panel does not display any error codes. I'm going to answer my own question: I removed 2 screws and removed the panel holding the display. One the left side, as you face the oven was a small ribbon connecter that had come loose. I pushed in the terminals on both ends of the ribbon connector into their respective recepticles. I put back the panel, making sure that I didn't pull on and/or strain the ribbon as I buttoned it up. Works fine now. Just a loose connection!
