I am attempting to remove the oven door on my oven, Jenn Air JJW8530DDS. How does it come off? I want to clean the inside of the glass. Does anyone have instructions on how to take the door apart to do this?
Also. the door won't completely close without pushing on it which is causing the oven light to stay on. Do the hinges need to be replaced? If so, what part and how do I replace it?
The following has door removal info. http://www.maytag.com/digitalas...ns%20-%208101P602-60.pdfOften just removing the door and reinstalling it will solve closing problems. Here are your parts. Parts for Jenn-Air JJW8530DDS Oven - AppliancePartsPros.comNote that the hinge is shown as two item in section 03 Item 5 is just a hinge. Item 2 is a hinge kit. Often when you see a kit it is that the model has had problems with those parts. I do not have a manual for this unit. To replace a hinge. Remove the door from the unit and place it on blanket/towel on a a counter or table with the handle off the table. The door will then lay stable. Then just start removing screws to get the inner pane off. Take pictures or make yourself notes or mark the parts of anything that could be re-installed incorrectly. |
THIS FORUM IS DEAD!!!!!!! |
Thanks so much for all of the information.
