I've got a kenmore side by side fridge that is leaking water through the bottom of the ice maker. The leak is so bad it's just like turning on the faucet. Any ideas of what may be causing this?
One thing that can cause this is that the fill cup (where the water enters the icemaker) has gotten stopped up with ice. If so remove the ice and replace the water inlet valve. Icemaker Repair Guide
