naperjp
#1 Posted : Wednesday, November 5, 2014 9:40:38 AM(UTC)
naperjp
I had my refrigerator in storage for a few months this summer, and when I hooked it back up a few weeks ago the freezer was blowing warm air and neither the fridge nor freezer were cooling. I replaced the cold control hoping that would fix my problem, but no such luck.
I've been digging around, and chatting with various people, but I keep getting different recommendations on what the problem might be. Everything from defrost thermostat, to relay/starter kit, to freon, to compressor.
Here is what I know, the refrigerator runs fine and blows air, but it is warm. The compressor runs, but is hot to the touch. I do not have a lot of expertise, or testing equipment. Does anyone have any suggestions based on my model of what this might be that I can repair myself?
Thanks in advance.
John
Model Kenmore 253.69802892, top mount freezer, bottom fridge.
#2 Posted : Wednesday, November 5, 2014 10:13:13 AM(UTC)
Since the compressor runs and there is no cooling at all it is a sealed system problem.
This will be an expensive repair as you need a pro and often it makes more sense to put those dollars towards a new unit.
Check your warranty some systems have a longer sealed system warranty.
One thing to note is that you said it was in storage so I am assuming that you moved it. If it was moved on it's side it should have been left sitting upright for 24 hours before plugging in.
[COLOR="Blue"]Everything from defrost thermostat,[/COLOR]
the freezer would be cool just not cold enough
[COLOR="Blue"]to relay/starter kit,[/COLOR]
the compressor would not run or keep cycling on/off every couple minutes
[COLOR="Blue"]to freon, to compressor.[/COLOR]
Could be either of the above both will be expensive.
