snyperj
#1 Posted : Tuesday, November 4, 2014 4:34:43 PM(UTC)
snyperj
I took the back plate off and notice some burnt insulation around what I think are the connectors to the top element? Another component also shows some burn...tried to post pics but form rejected me from doing so.
Any suggestions on this limited info?
snyperj attached the following image(s):
snyperj
#2 Posted : Tuesday, November 4, 2014 4:37:59 PM(UTC)
snyperj
It is hard to see the burn in the pictures but on the two lower pictures the insulation is burnt... on the component picture there is burning on both sides where the bracket is making contact...
#3 Posted : Wednesday, November 5, 2014 12:30:03 AM(UTC)
I cannot comment on the top photo as I cannot see much.
The lower two look normal to me.
Often this is not the insulation burning.
It is fumes that have escaped from the oven when cooking.
They condense on the cooler insulation and then change color over time.
snyperj
#4 Posted : Saturday, November 8, 2014 4:39:00 PM(UTC)
snyperj
You were correct..it wasn't coming from there. Down near the bottom edge of the stove was a small access panel. I took that over and discovered this is where the AC plug is connected...and this is where I found the source of the problem. Sears delivered and installed this stove in March 2013, so not sure why this happened now...but it has. What would be my best method to repair..suggestions welcomed and needed!
#5 Posted : Sunday, November 9, 2014 2:15:37 AM(UTC)
Looks like a bad connection on the right side of the terminal strip.
Could have been just a bad/loose connection here from day 1.
Here is how it can happen.
Electricity see a bad connection as a resistance.
So as current passes through it it heats up/arcs etc.
This further degrades the connection causing more heat and so on and so on till the connection fails.
Get a new terminal strip and replace it.
Carefully check the connectors on the wires to be sure it is not them that is heating up.
Clean the connectors with fine emery cloth etc. till they are nice clean copper.
snyperj
#6 Posted : Monday, November 10, 2014 4:49:28 PM(UTC)
snyperj
Thanks- picked up the terminal strip today at a local parts supplier (and some emory cloth..) and all is working again toinight. Thanks for the help!
#7 Posted : Tuesday, November 11, 2014 1:02:24 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
It would not be a bad idea to pull the stove out after you have used the oven half a dozen times or so and take a look at the terminal strip for any signs of overheating, just to be on the safe side.
