I have a admiral Ref lsd2615hew,,, the model/serial sticker is badly damaged, I just installed a new compressor and I can't read the "weigh in" charge. Any way this can be found?
Did you suck down the system, both high and lo?
Yes of course,,,,I do this for a living. I charged it till the pressures were right, which took almost 5oz....but Im still curious to know if thats right.
I usually charge till I reach the R12 or R138 pressure per the pressure/temperature chart. Without an accumulator in the freezer and the frost line away from the compressor, you should be ok.
