Barb L.
#1 Posted : Sunday, November 2, 2014 5:15:24 PM(UTC)
Barb L.
The light above "clean" is flashing. And it will not take any other commands. Anyone got any idea how to clear this? It is 8 years old.
#2 Posted : Monday, November 3, 2014 1:16:44 AM(UTC)
Parts for DUL240XTPQ - AppliancePartsPros.com
You are missing the last digit in the model number so you will have to choose the correctunit in the Matching Model Numbers section.
Try removing power from the unit for a couple minutes to see if it will shut off.
If it does not or the problem re-occures then you will have to delve into the tech sheet.
File Attachment(s):
DUL240.pdf (162kb) downloaded 1 time(s).
