3 Pages123>
jessman1128
#1 Posted : Monday, October 27, 2014 9:09:10 PM(UTC)
jessman1128
Our Whirlpool Quiet Partner III started acting up today. We normally run it on the Normal cycle with Heated Dry, and today was no different. I noticed at some point that the display had been stuck on 63 minutes for quite some time (close to an hour), and it had continued making noise during that entire time. It never did move past 63 minutes. I eventually canceled that run. I then ran Rinse Only and Light cycles and each finished successfully. Just started a new Normal cycle w/ Heated Dry a little bit ago, and it got stuck on 63 minutes again. I let it go for awhile and then canceled it. It sounds like it is circulating water inside the dishwasher the entire time it is on 63 minutes.
Any ideas what the problem might be?
#2 Posted : Tuesday, October 28, 2014 1:17:33 AM(UTC)
Parts for Whirlpool GU2400XTPT3 Dishwasher - AppliancePartsPros.com
Sounds like a water heating problem.
The unit is waiting for the water to heat up and reach a set point temperature and for some reason it is not doing this.
First try removing power for a couple minutes to see if this will reset the unit.
If this does nothing.
Remove power from the unit and check the hi-limit thermostat. It should be 0 ohms.
If OK
This step might be easier if you check it at the control board as you would probably have to pull the dishwasher out from under the counter to check just the heating element.
Unplug the unit and remove the inner door cover so you can get to the control board.
Check from P6 to the W-V (white/violet) side of the door switch.
Should be around 20 ohms.
Note that this checks the heater and the hi-limit thermostat.
IF OK
With power still off check across the door switch.
Should be 0 ohms when activated.
Also check that the latch is OK to be sure that the switch does close when the door is closed.
If OK
Check the thermistor, it is what measures the temperature.
P2-2 to P7, see the wiring diagram for the spec.
If OK then odds are that the control board is the problem.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
GU2400.pdf (162kb) downloaded 74 time(s).
jessman1128
#3 Posted : Tuesday, October 28, 2014 8:51:28 AM(UTC)
jessman1128
Thank you for the advice! I'm hoping to find time tonight to work through your instructions. In the meantime, I neglected to mention in my original post that both times it got stuck at 63 minutes the water was hot when I opened the door to check inside. Whether it was as hot as it was supposed to be, I can't say. Anyway, if that additional piece of info changes any of your advice please let me know.
jessman1128
#4 Posted : Friday, October 31, 2014 2:17:27 PM(UTC)
jessman1128
Ok, I finally found time to open up the dishwasher. For all of the checks that involve the control panel, am I disconnecting the relevant wire first or leaving it connected? And then am I checking the wire or the control board pin? I didn't see instructions on the sticky topic for those types of checks - just isolated component checks.
jessman1128
#5 Posted : Friday, October 31, 2014 6:44:57 PM(UTC)
jessman1128
Ok, I think I figured out how to test these various items.
Thermostat was a bit of a pain to get to, but I removed it and it tests at 0 or just above 0 (0.1, 0.3 and so on).
For P6 to W/V on door switch I removed the wires from the terminals and inserted the multimeter leads into the wire ends. It showed 10 ohms. Wiring diagram lists a range of 10-30 for this one, so I think that means it's okay. Let me know if not
Couldn't quite figure out how to test the door switch.
For thermistor I wasn't getting any reading, but I also couldn't tell if I had a good connection on P2-2, due to the design of the wire "bracket" that attaches to the terminals. I found a couple other ones to test that were on that bracket. The Fill Valve - P10 to P2-3 - showed ~890 ohms and diagram has range of 890-1090. Also the Dispenser - P10 to P2-4 - showed ~280 ohms and diagram has range of 280-340. Tested P2-2 to P7 again for the thermistor and still nothing. Assuming that means the thermistor is bad and I should order a new one? Assuming so, does it have another name besides thermistor, because I'm not finding a thermistor in the parts diagrams for this model.
#6 Posted : Saturday, November 1, 2014 5:06:52 AM(UTC)
[COLOR="Blue"]Thermostat was a bit of a pain to get to, but I removed it and it tests at 0 or just above 0 (0.1, 0.3 and so on)[/COLOR].
Looks OK
[COLOR="Blue"]
It showed 10 ohms. Wiring diagram lists a range of 10-30 for this one, so I think that means it's okay. Let me know if not[/COLOR]
Looks OK
[COLOR="Blue"]Couldn't quite figure out how to test the door switch.[/COLOR]
Make sure that the switch is activated by the latch.
Pull both wires off the switch (should ba a white and a white.violet.
Should measure infinite ohms.
Now manually activate the switch, should drop to 0 ohms.
[COLOR="Blue"]Tested P2-2 to P7 again for the thermistor and still nothing. Assuming that means the thermistor is bad and I should order a new one?[/COLOR]
Yes it does as long as you were using the correct meter scale (high enough) (200 K scale).
One thing to note is that it also could be an open connection wire from the control board to the thermistor.
[COLOR="Blue"] Assuming so, does it have another name besides thermistor, because I'm not finding a thermistor in the parts diagrams for this model.[/COLOR]
They call it a thermister (item 25 in section 08)
jessman1128
#7 Posted : Monday, November 3, 2014 9:43:09 AM(UTC)
jessman1128
Ok, the switch sounds like it is being activated by the latch. With the switch wires removed, the switch terminals tested infinity. With the switch activated I couldn't get a consistent reading. At times it would drop near 0, but never reached 0, and sometimes was as high as 10 or 20. This was with the 200 scale.
See picture below of the terminals. One is shiny, the other is not. Not sure if that's relevant or not.
UserPostedImage
Yes, that's the scale I was using.
Ah - different spelling. That's why it didn't show up when I used the search function. Thank you.
#8 Posted : Tuesday, November 4, 2014 12:22:25 AM(UTC)
Yes the switch looks like it is toast.
I would replace it.
Be sure to clean the connector on the wire as best you can so it makes good contact to the switch lug.
jessman1128
#9 Posted : Wednesday, November 5, 2014 11:09:18 AM(UTC)
jessman1128
Ok, thank you. Ordered parts yesterday, they arrived today. I'm a little confused now. I removed the old thermister and hooked up the new one, and then tested P2-2 to P7 again with no change. On the 200 scale, my multimeter shows 1 with the leads not connected to anything. When I connect them to P2-2 and P7, it still shows 1. I decided to test the old thermister directly, thinking that I could test the metal tabs directly and it also showed a 1. (I think that means infinity?) So then I removed the new thermister and tested that directly and it also is showing a 1. I tested the thermostat again to make sure the multimeter was still working correctly and it is. Does this mean I received a bad thermister?
#10 Posted : Wednesday, November 5, 2014 11:19:47 AM(UTC)
I think you are on the wrong meter scale not 200 but 200K which is 200,000 ohms.
Guest (4)
3 Pages123>
