2 Pages<12
aruba28
#11 Posted : Tuesday, May 12, 2009 1:15:42 PM(UTC)
aruba28
I got one load through and now, no heat! Have checked the heat sensor on blower housing and the fuse on the inside rear panel. Fuse showed 0, sensor about 3 ohms. Also checked 2 ceramic fuses (?) on top of the unit where the gas comes in; they show a couple of ohms each. What else can I check?
#12 Posted : Tuesday, May 12, 2009 2:01:29 PM(UTC)
I would check for continuity the igniter, the safety thermostat (#33 on the diagram), the flame sensor (#79 on the diagram) and the temperature selector switch (as shown on the wiring diagram).
Post the results.
aruba28
#13 Posted : Tuesday, May 12, 2009 2:31:35 PM(UTC)
aruba28
OK, #33 I'd already checked (thought it was a fuse). Should it read 0 or a couple of ohms? The flame sensor will require a very short PHillips screwdriver which I'll have to borrow.
#14 Posted : Tuesday, May 12, 2009 3:32:06 PM(UTC)
The continuity test should show close to zero reading for a closed circuit.
You can find more information from the article on our forum - [COLOR="Blue"]How To Check Continuity With Ohmmeter[/COLOR].
Guest (10)
2 Pages<12
