jbili
#1 Posted : Thursday, October 16, 2014 3:37:51 PM(UTC)
jbili
Hello all. I have a 30" KitchenAid freestanding slide in gas range and oven
I am getting the error code F1 E3 intermittently. The oven will work fine for a while and then will shut itself off and repeatedly give this code.
The next day it will work fine.
The oven wasn't moved recently and was just wondering what may cause this error code to come up all of a sudden.
The code book says configuration mis-match check jumper cables.
I ran an end of service test sequence and got the results
6AS
Eb-SI
Oven stays on for a while and then just goes off.
Pretty hard to cook dinner with this going on.
If you have to open the door to check food while cooking 9 out of 10 times the oven spazzes out. sometimes you get the code, sometimes it gives you funky readings.
Press 350 and out pops 80 or better yet 800 degrees or else you get a 250 temp probe
Can anyone help
Thanks in advance
Joe
jbili
#2 Posted : Monday, October 20, 2014 2:10:00 PM(UTC)
jbili
Can anyone help
jbili
#3 Posted : Friday, October 24, 2014 3:12:20 PM(UTC)
jbili
Anyone please
