swillcox
#1 Posted : Friday, October 24, 2014 6:50:17 AM(UTC)
swillcox
Recieved new part to replace broken handle on latch. Can not seem to disconnect the switches inside the panel in order to reattach new assembly. Please help
#2 Posted : Friday, October 24, 2014 9:09:12 AM(UTC)
Part number: AP4264081
Click on the picture of the parts for more info about it.
Look at the connector to see if it has a small latch that has to be pushe to release the connector from the switches.
Wiggle the connector from side to side while trying to pull it off.
Sometimes inserting a flat blade screwdriver between the switch and the connector and then twisting the screwdriver will force the connector off.
