I have a Whirlpool WDT790SAYM that was installed in June of 2013. Starting last month we noticed that mid cycle it would start beeping and the resume light would start flashing. We would open the door, hit start/resume and it would either finish the cycle or require another start/resume. I took the dishwasher door apart and measured the 2 points on the board as defined in the manual. Than manual said if the resistance was less the 3 ohms then the board was fine. Both points measured around .1 ohms, so it everything seemed fine. Put everything back together and powered dishwasher on and dishwasher ran flawlessly :confused: . Now this morning push start close door and instantly dishwasher starts beeping and asking for start/resume to be pushed. Open door, push start/resume, close door, starts beeping. Thanks in advance for any responses.
I replaced the electronic control board. During the first run it stopped about 30 minutes into it. The start/resume button flashing. I opened the door and hit start again then it ran. What could this issue be?
