My Frigidaire Gallery gas oven will not heat up enough. I set the oven on 350 the igniter will light up and the burner will light. It will only stay on for about a minute or so and then the oven beeps as if it is preheated and the preheat light goes out. Then the burner will go out. With the oven set on 350 the temp will only get to about 150 per the thermometer I set on the rack. I have already replaced the oven probe and installed a new igniter. the only things left are the safety valve, per the web that doesn't go bad very often. And the ECM Electronic Control Modual. Is there a factory reset I can do or something? I've not been able to find one on the web. Something is out of wack and it thinks it is preheated and goes out. I thought a factory reset might do the trick. This will be the second ECM I have had to put in this thing. Please help out
What does it take to get a reply to a post? I posted a question about my oven four days ago. 77 people looked at it and still no reply. Based on the question, I was hoping for an answer before I purchased a 100 dollar part.
Thank you
