Cochese
#1 Posted : Monday, October 20, 2014 6:30:55 AM(UTC)
Cochese
Hi All,
Noticed a leak coming from under the base panel of my Bosch DW. Opened up the base and started a cycle to get a look at the source, and got a clear look at water welling up and dripping (fairly rapidly at times) from the base of the Thermistor, where it meets the housing in the heating element. I did pull it out to look at the O-ring, and didn't see anything unusual, but was not able to fix it with my attempt at "re-setting" the O-ring. I ordered a new O-ring and am going to try replacing it. Is there anything else I can do to fix this, or am I missing anything/wasting my time? I checked the heating element carefully for cracks and everything looked in order.
Thanks in advance for your wisdom and assistance!
