Problem: Wall mounted oven will not reach set temperature at 300 degree and it take 30 mins to get up to 160 deg (max)
Tried: - Check both bake elements continuity and they are fine - Check temp sensor is fine (~1200 ohm)
At a loss on what to try next.. - Do I need to check or replace the thermostats? Which one? and how (what to look for)? - Do I need to replace the controller/timer?
Any help will be appreciated.
I took it apart again and checked the connection in the block (look solid). Then reset the thermos switch (resettable with the press on the red button)
Switch, Thermal)The oven is now working. The door is still leak a bit and will look at adjusting the hinge to see if it will seal better. Best of luck..
