Dave1234567
#1 Posted : Sunday, October 19, 2014 5:45:40 AM(UTC)
Dave1234567
I've replaced both timer and door switch
My dryer will run with door shut and timer in off position.
I disconnected buzzer, even with door shut and in off position it keeps the buzzing noise.
I have to unplug when not using
Really confused, can anyone help
fairbank56
#2 Posted : Sunday, October 19, 2014 10:41:05 AM(UTC)
fairbank56
Groups: Expert
If the dryer tumbles (motor running) with timer in OFF position, then the timer is bad or it's wired wrong. In OFF position, power is removed from the motor via opening of timer contacts. What is it that is buzzing? Can't be the buzzer if you disconnected both wires to it.
Eric
Dave1234567
#3 Posted : Sunday, October 19, 2014 2:38:01 PM(UTC)
Dave1234567
I've tried to find a wiring schematic to check my wiring.
The timer is labeled for wires.
To check if the timer is correct, it is the second timer and second door switch.
The buzzer is disconnected
This thing really pis...s me off.
Any kind of help would be great.
Dave
fairbank56
#4 Posted : Sunday, October 19, 2014 3:52:09 PM(UTC)
fairbank56
Groups: Expert
Here is your wiring diagram. That's about all I can do for you without more feedback.
Eric
File Attachment(s):
8528187.pdf (333kb) downloaded 4 time(s).
Dave1234567
#5 Posted : Sunday, October 19, 2014 4:37:38 PM(UTC)
Dave1234567
I'll give your wiring schematic a try
Dave1234567
#6 Posted : Sunday, October 19, 2014 4:42:46 PM(UTC)
Dave1234567
As soon as I do I'll let you know
In Ohio for the next few days
Will be around Wednesday
Surprised with the quick response
You guys are great
Guest (4)
Whirlpool dryer won't stop running (Dryer Repair)
by dryrprob 10/15/2007 4:26:13 PM(UTC)
