I just received my new start relay and it is different than the original. The original had only two prongs and the new one has 3 prongs. I am trying to figure out where to connect the wires on the new relay. I know the blue wire goes on the overload but where does the double orange wire and the white wire go to on the new relay? I also just realized the orange wire connection is too small for the prongs on the relay, so what can I do to fix that as I do not know too much about electrical.
If you have an ohmmeter, I can help. If you made a diagram of the old wiring, that would help.
