maharris
#1 Posted : Wednesday, October 15, 2014 5:10:13 PM(UTC)
maharris
New to the board and thanks for any help that you may provide.
I have a Kenmore model 665.16374301 and I recently noticed that I was having issues with my Kenmore dishwasher. Replaced a bad chopper assembly, and check valve. I did notice that the new check valve was larger in diameter than the old one. I attributed this to 9 years of swelled rubber. I am going to assume that the new check valve is the suitable diameter to serve it's purpose.
My issue is that I noticed the main pump seems to be running dry after a few minutes of washing. I verified this by opening the door during the wash cycle to see that the sump/basin is dry. I can fill it back up with water from the sink, and it will wash fine for a while, but then it will run dry again. Another side issue is that I notice that the heating element has been energized, because it is hot.
I've read quite a bit about siphoning, but I don't think this is my problem. One thing I did to check for siphoning was to fill the bottom of the dishwasher with water, and let it set. after a few hours, I still have all of the water. If siphoning, I'd assume it should be gone.
I have a suspicion that the control board or possibly the temperature sensor could be causing issues with the wash sequence.
Here are the questions that I have:
1. I've read about a turbidity sensor in some models. Is the soil sensing in this model achieved by the temperature sensor?
2. Can I bypass this sensor for a "safe-mode"?
3. Am I on the correct path thinking control board or temperature sensor?
maharris
#2 Posted : Wednesday, October 15, 2014 6:53:53 PM(UTC)
maharris
Here's an update, with a follow-up question.
I decided to pull the thermistor. When I pulled it, I found that it was coated with a nasty film. I cleaned it quite well, and decided to check it with the ohmmeter. The resistance measured ~49k ohm at room temp, and when I put it into 115 degree F water, the resistance immediately went to 24k ohm.
If the probe was coated, I could see how the effectiveness would be in question.
I now know that the thermistor is good, but I wish I had checked it in hot water before I cleaned it. Gonna try another load tonight, and see if it still drains.
If it does, should I go ahead and try the control board? Do the symptoms in the original post indicate control board issues?
maharris
#3 Posted : Friday, October 17, 2014 6:41:41 AM(UTC)
maharris
Took the board out, and saw nothing obviously burned. Guess I can try the board. Not much else to replace since I know that the heater element, drain pump, circulation pump, and temp. sensor are working.
Am I missing anything? Tried another load last night. Washes well for a few minutes, and then I hear the dry circulation pump running. I open the door and the sump is empty, and the heating element is hot.
This is driving me crazy.
