vuanhmai
#1 Posted : Tuesday, October 14, 2014 1:27:13 PM(UTC)
vuanhmai
I have a 2008 LG fridge and it just stopped cooling. There are clicking sounds each 2 or 3 minutes interval. The fan is running. There is no error code in the Control Panel display in the front.
Can anyone have any recommendations?
barryware
#2 Posted : Wednesday, October 15, 2014 1:07:11 PM(UTC)
barryware
sounds like the compressor start relay.
it is typically plugged into the compressor, and the power wires connect to the relay.
if you remove it and shake it.. if it rattles, it is no good and must be replaced.
