forrestdad
#1 Posted : Tuesday, October 14, 2014 12:29:05 PM(UTC)
forrestdad
I can't seem to find the defrost timer or defrost thermostat for this model of GE 'Profile' bottom freezer (Mod.). Is it all electronic on a board somewhere? the cabinet drawings only come back with a hit for the defrost heater. "stewbeans22" was very helpful but I am stuck. Is it a bad timer, thermostat, or Heater element (last one less likely as it looks new and un damaged). The heater element I can see but not the other 2... cant test what I cant find, and I am hesitant to cut the wires to the heater to test it directly. Ideas?
#2 Posted : Thursday, October 16, 2014 2:15:01 AM(UTC)
What is your problem and correct the model #
forrestdad
#3 Posted : Thursday, October 16, 2014 8:34:00 AM(UTC)
forrestdad
GE PDS20SBRALSS is what it says on the inside of the door, the problem is a lack of defrost is causing a weekly ice dam to form. I believe that my model must have an electronic timer circuit (vs. a motor that can be manually advanced to test the heater) I can see several thermal pick-ups (one in the freezer section strapped to the cooling coils) presumably this is the one sensing the need for defrost. The heater element looks new and undamaged so I think this is not likely to be the issue, and since It looks like I would have to cut its wires to check continuity I am hesitant. I have not yet located a circuit board and I don't want to back feed 120v to it (if there is one) with a poor trouble shooting protocol. Ideas?
#4 Posted : Friday, October 17, 2014 12:47:13 AM(UTC)
Pull out the fridg and remove the screws from the metal motherboard cover.
Locate the 3 pin, gray power connector and remove it. Put a wire jumper between the mating pins labled line and def. Plug fridg in. If it goes in defrost, you have a bad motherboard, if not, probably either a bad defrost heater, or a bad defrost thermostat clipped to the top of the evaporator, a round metallic thing. I would replace both. Order them on this site.
forrestdad
#5 Posted : Friday, October 17, 2014 7:25:00 AM(UTC)
forrestdad
hey great! that's a tremendous help. I'll give it a go tonight!
forrestdad
#6 Posted : Monday, October 20, 2014 9:08:43 AM(UTC)
forrestdad
Finally had a chance to look at the fridge and it was just as you said and the jumper did indeed turn on the heater element, thank you for that. So the supposition was a bad board. There was however a mysterious and suspect cut white wire going to a white multi-pin connecter at the top right of the board(maybe a dozen sockets (not all used)). the cut wire split out from a lump in the line (line filter?) along with another white wire still intact. I figured I was on the hook for a new board any way so I soldered it back together and plugged it in... no blue smoke. Any idea what it was or if perhaps this was part of the nonfunctioning defrost system? A timer relay maybe?
#7 Posted : Tuesday, October 21, 2014 12:28:52 AM(UTC)
I think that was going to a thermistor. Still all points to a bad board.
forrestdad
#8 Posted : Tuesday, November 11, 2014 8:28:39 AM(UTC)
forrestdad
up date: replaced the board and 10 days later it Iced over again! I used the jumper trick to manually check the heating element and circuit was still working ran it for 20 min and restarted the fridge ice dam gone. So I don't have to manually defrost but still tedious every week to 10 days to pull out the fridge and such. Also the ice maker is not working. iced over supply? (though I don't think it has since the new board, and this was not previously a problem and we are a family of smoothie makers). Ideas anyone? 11/13 ...And again so now with it raining here the humidity is up and I have to defrost every 3-4 days and still no ice in the icemaker. Is there a way to test either the old board to see if the one I got is bad or is there an other component to test... defrost thermostat maybe? can this be tested without cutting the wires?
forrestdad
#9 Posted : Monday, November 17, 2014 4:52:50 PM(UTC)
forrestdad
called the APP store and the phone person said they thought I should replace the damper apparatus.... Yes, if bad, this would prevent the air from moving into the fridge but so would the ice dam that forms every 2-3 days... I have a defrost problem. I do not believe it is the defrost thermostat now b/c if failed 'closed' it would over warm the freezer but certainly defrost if failed 'open' I would not be able use a jumper to manually activate the defroster element (which works well). Is there a conventional timing circuit somewhere on this unit?
