ez211
#1 Posted : Monday, October 13, 2014 8:18:40 AM(UTC)
ez211
smoke started coming from under frig
unplugged took back cover off smoke coming from starter
do I need to replace starter and compasiter relay both
#2 Posted : Tuesday, October 14, 2014 1:24:48 AM(UTC)
Yes, use part #241707701 Check the compressor pins for molten metal. If there, use a dremel grinder to fix.
