mdcsd
#1 Posted : Saturday, May 9, 2009 1:01:07 PM(UTC)
mdcsd
The upper spray arm is not rotating and I suspect low pressure due to bad seals on the middle and lower arms. My problem is that I can't get the lower arm off to check the seal or clean the screen. The arm is metal and it sits in a plastic cradle. The arm has a plastic plug in the center which I can get to rotate but it doesn't unscrew. A parts diagram on the Sears web site doesn't show this plug or any screw. Thanks for your help.
Terryr
#2 Posted : Tuesday, May 12, 2009 10:22:17 AM(UTC)
Terryr
Found this link on the forum. Take a look at paragraph 4 in "Rremove/reinstall wash pump assembly" at https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
mdcsd
#3 Posted : Tuesday, May 12, 2009 11:41:05 AM(UTC)
mdcsd
Terry,
Perfect. That solved the problem. I don't have it apart yet but the procedure (who would have thought) is there. Thank you for your help.
Malcolm
