Samsung dryer would flip the breaker and lose all power when the start button was pressed and the motor started to turn I replaced 2 30 amp breakers and I thought this fixed the issue the dryer would start and run with heat but it was still flipping one of the 30 amp breakers. This happens even on fluff cycle. ON timed cycle their is heat I'm just not sure it is as hot as it should be. I thought I needed 220 for the heating element to heat?? I have 110 at the outlet , I know this states the obvious, any ideas on what part I need to check and how? thanks judesson
