smylist
#1 Posted : Sunday, September 28, 2014 7:52:50 PM(UTC)
smylist
My interior oven light will not shut off, no matter how I hit the control pad button for it, which make the beep sound when it is pressed. I have changed the read-out panel twice (which had died), but the light remains on, although everything else seems to work.
#2 Posted : Monday, September 29, 2014 1:53:19 AM(UTC)
Parts for Jenn-Air JJW9530AAQ Oven - AppliancePartsPros.com
Here is a manual.
You will have to join the site and be logged into be able to download it.
http://appliancejunk.com...&id=414;t=1411984248
If the door switch is OK then odds are that the problem is on the relay board (item 11 in section 04)
