Steve8120
#1 Posted : Sunday, September 28, 2014 6:48:28 PM(UTC)
Steve8120
Dryer stops 1 minute after starting with E1 error. Replaced thermistor -- still E1 error. Replaced thermostat and thermal cutoff -- still E1. Thermistor checks OK and wiring to control board checks okay. Is the Control Board the likely culprit?
#2 Posted : Monday, September 29, 2014 3:14:02 AM(UTC)
Parts for Whirlpool GEW9250PW0 Dryer - AppliancePartsPros.com
I agree with you that the control board is the most likely culprit.
If ordered from AppliancePartsPros, it can be returned if it does not fix the problem.
Please see their return policy.
