myrnarud
#1 Posted : Wednesday, September 24, 2014 7:15:11 PM(UTC)
myrnarud
After using the self clean cylcle the oven nor the broiler works. I had this problem before, took it apart and wiggled things and blew dust off. After turning the circuit breaker off over night, it worked. Now it doesn't work again after using the self clean. I relplaced the main control panel and now am wondering if it is the elctronic clock oven control panel. I read about the possiblility of it being the termal fuse, but cannot tell by the pictures if this built-in model has one or where it is. I don't see it on the list of parts. The clock control is no longer available.
#2 Posted : Thursday, September 25, 2014 12:51:53 AM(UTC)
You should look in the Matching Model Numbers section for the correct series number.
Parts for AOES3030WW - AppliancePartsPros.com
See the attachment for the tech sheet
The first thing I would check is the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Yes there looks like there is a hi-limit thermostat. I think it is item 38 in section 02 but am not 100% sure so you will have to trace the wires to confirm that it is the correct part to check.
I am assuming that the unit stays in preheat and never comes ready.
File Attachment(s):
AOES3030.pdf (244kb) downloaded 3 time(s).
Amana oven not heating at all (Oven Repair (including Ranges and Cooktops))
by dmay21 10/5/2010 10:35:25 PM(UTC)
