Stormdog
#1 Posted : Sunday, September 21, 2014 1:29:08 PM(UTC)
Stormdog
I inadvertently replaced the High Temp limit switch and Therrmostat limit switch) with a 309 deg switch instead of the correctly speced 350 degree switch.
The dryer ran for about 8 loads and now the switch is blown (again).
Is it likely the problem is using the wrong switch or indicative of another problem that I have not yet found?
#2 Posted : Wednesday, September 24, 2014 2:36:27 AM(UTC)
Parts for Whirlpool LE7680XSW1 Dryer - AppliancePartsPros.com
[COLOR="Blue"]
Is it likely the problem is using the wrong switch or indicative of another problem that I have not yet found?[/COLOR]
I cannot say for sure as I do not know the temperatures at the heater coil so perhaps the 309 is too low. The unit would then be regulated by the hi-limit.
Unlike the cycling thermostat it's contacts are not hardened so they fail after cycling for a while and then can blow the thermal cut-off.
But if you did not find a cause for the thermal cut off blowing in the first place I would take a closer look.
Below is my standard blurb on thermal cutoff problems.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
