philton66
#1 Posted : Saturday, September 20, 2014 7:48:34 AM(UTC)
philton66
The right dual burner will not come on. Technicians came in several times repaired burnt shorted out wire and the burner still does not come on.
Is it the burner or the wiring?
#2 Posted : Tuesday, September 23, 2014 12:10:27 AM(UTC)
Parts for Maytag MER6875AAQ Range - AppliancePartsPros.com
See the attachment for your tech sheet
[COLOR="Blue"]Is it the burner or the wiring?[/COLOR]
I cannot say.
I would check the element visually and with a meter.
Also why they fixed a burned out wire twice and what else if anything did they check would be helpful.
File Attachment(s):
MER6875.pdf (253kb) downloaded 0 time(s).
