BWatts
#1 Posted : Monday, September 15, 2014 8:00:18 AM(UTC)
BWatts
I have a GE JBP65GV1WH 10.1 7.6 Serial # SM222379G
that pre-heats fine, then after a few minutes, the self-cleaning light comes on and it says to pull the lever for self cleaning. The stove goes cold. Any suggestions as to what it could be?
#2 Posted : Tuesday, September 16, 2014 1:51:27 AM(UTC)
Parts for GE JBP65GV1WH Range - AppliancePartsPros.com
Sounds like a control board problem.
The board looks like it is obsolete.
I would try unplugging (or shut the breaker off ) for a couple minutes to see if the board will reset itself.
