Ayr40@aol.com
#1 Posted : Monday, September 15, 2014 5:00:20 PM(UTC)
Ayr40@aol.com
The ice maker makes ice but it does not drop it into bin it makes a turning noise but does not drop I have to move out ice manually
#2 Posted : Monday, September 15, 2014 11:53:02 PM(UTC)
Does the ejector arm on the ice maker rotate so that it is touching the ice cubes and then stalls at that point.
If yes then the cube tray heater is probably bad.
On most units once the ice and tray gets down to about 15 degrees F the ejector arm moves to push the cubes out, the tray heater comes on. This loosens the cubes and then the ejector arm can push them out.
Ayr40@aol.com
#3 Posted : Tuesday, September 16, 2014 3:56:09 AM(UTC)
Ayr40@aol.com
Where is that arm on the ice maker so I can see if it rotates
#4 Posted : Tuesday, September 16, 2014 4:01:19 AM(UTC)
Below is an example of a standard ice maker.
The fingers are part of the center shaft.
Part number: AP4360354
Ayr40@aol.com
#5 Posted : Tuesday, September 16, 2014 10:28:24 AM(UTC)
Ayr40@aol.com
It seems that nothing really rotates once it makes a turning noise the ice is loose enough to pull out by hand but does not fall out. Then the process starts again. Any thoughts. Do I need a new ice maker
Ayr40@aol.com
#6 Posted : Tuesday, September 16, 2014 12:00:35 PM(UTC)
[COLOR="Blue"]Do I need a new ice maker[/COLOR]
Sounds like either the motor is shot or one of it's gears.
A new ice maker would fix the problem and is usually the easiest fix.
Ice makers can be a bit of a pain to fix.
Also I do not know what the parts to repair the unit would be.
Ayr40@aol.com
#7 Posted : Tuesday, September 16, 2014 12:04:03 PM(UTC)
Ayr40@aol.com
Thanks I appreciate all the help and advice
Ayr40@ail.com
#8 Posted : Tuesday, September 16, 2014 12:08:04 PM(UTC)
If you have the model number you can look up the parts and new ice maker cost.
Find your model number - AppliancePartsPros.com
