vincentjlawrence
#1 Posted : Monday, September 15, 2014 1:51:35 PM(UTC)
vincentjlawrence
Refrigerator running much too cold - turned temp control all the way down - did get some temperature rise (baffle may be working). First thing I want to do is replace the thermistor - but before I take things apart - Where is the thermistor in the refrigerator section??? It is not obvious without disassemble. The parts explosion is useless for finding the part.
Thanks,
Vince
#2 Posted : Tuesday, September 16, 2014 12:44:17 AM(UTC)
See the attachment for the tech sheet
File Attachment(s):
KSSS42QD.pdf (707kb) downloaded 17 time(s).
vincentjlawrence
#3 Posted : Tuesday, September 16, 2014 9:10:51 AM(UTC)
vincentjlawrence
denman,
Thanks - I must be blind as I looked directly at it... I will keep the parts locations diagram in the refigerator file.
Again thanks!
