MswGirl
#1 Posted : Monday, September 15, 2014 7:58:39 AM(UTC)
MswGirl
No matter which wash setting I choose, the washer starts filling but drains before it gets a couple of inches of water in the tub. Since it will never get full, the timer never advances (no matter which of the four wash settings I start). I'm assuming it isn't the timer (I guess it can't advance if the first part of the cycle never gets done), but what else should I check? I have no appliance repair experience, but I'm willing to try (since I'd rather not buy a new washer). Thank you!
fairbank56
#2 Posted : Monday, September 15, 2014 11:20:57 AM(UTC)
fairbank56
Groups: Expert
Sounds like a siphoning problem. How is the drain hose arranged? If it goes to a standpipe in the wall and hose is too far down into the pipe or the connection is sealed, it will siphon the water out of the tub.
Eric
MswGirl
#3 Posted : Monday, September 15, 2014 11:23:56 AM(UTC)
MswGirl
Thank you, Eric! It goes into a standpipe in the wall. It has been there for over 4 years, and never had this problem. Could it be the standpipe is blocked?
fairbank56
#4 Posted : Monday, September 15, 2014 11:47:37 AM(UTC)
fairbank56
Groups: Expert
Where is the water going when it drains out of the tub? Does the drive motor come on and pumping it out or is it just draining/siphoning on it's own? Make sure the drain hose to standpipe connection is not sealed. There must be an air gap.
Eric
MswGirl
#5 Posted : Tuesday, September 16, 2014 6:23:55 AM(UTC)
MswGirl
Gosh, I feel like an idiot! I pulled on the drain hose, and it did appear to be sealed. I heard a sucking sound, and then some water from the hose drained down the house drain. It was definitely siphoning. I'm so glad you answered my question on this forum! You saved me a service call :) Thank you again!
Guest (6)
