I have to replace the water inlet tube. I have disconnected the lower nut and hose. The upper portion is inserted into the top left of the fridge, there is silicone around the area it is inserted into how do I remove the hose and will have to remove the back portion of the fridge to complete the reinstall. Thank you Scott
THIS FORUM IS DEAD!!!!!!! |
