I replaced a burned out burner and the indicator light. The burner works fine but the Hot Surface indicator light stays on all the time
Originally Posted by: James L Hoffert  I replaced a burned out burner and the indicator light. The burner works fine but the Hot Surface indicator light stays on all the time Is there a reset control?
