Dmitri
#1 Posted : Wednesday, September 10, 2014 4:30:26 PM(UTC)
Dmitri
My Maytag top mount fridge (MTB1954DRW) is 14 years old. I started noticing ice forming on the inside of the freezer door. I thought I simply needed to change the freezer door seal. When I removed the old seal and the freezer door liner, I found that behind the liner it was literally filled with ice. Frozen in the ice was a ring of foam insulation. It took me an hour with a blow dryer to remove the ice! My questions are this:
1) The piece of foam insulation appeared to be attached to nothing. I do not see the piece of foam insulation in any parts diagrams for my fridge online. What is its function if it just lies in there? Do I need to dry it out and put it back in place when I reassemble? Do I need to replace it?
2) What is the likely cause of this huge ice build-up? Is it possible that a new seal will fix this, or is there likely to be a bigger problem?
Thanks for your help, Dmitri
#2 Posted : Saturday, September 13, 2014 6:01:45 AM(UTC)
I was hoping someone else would jump in who actually knew what was going on.
Often a piece or Styrofoam is used as a spacer re: so that the liner cannot be pushed back causing it to crack. It is usually glued in place so you should see glue residue where it was (either on the door or the liner).
Now here is where I am totally confused as to what is going on.
Behind the liner I would think that it should have been full of insulation.
I am surprised that you did not have condensation on the outside of the door espacially on hot humid days.
