prichardh
#1 Posted : Monday, May 11, 2009 10:00:38 AM(UTC)
prichardh
We have the FC error code along with incessant beeping. We replaced the membrane panel a few months ago, so that should be good. I have studied the exploded view on the website, and in the wiring diagram, the error codes are listed, but are mostly illegible. It looks like it says J2 Harness or replace *****- something I can't read. In the parts list there is no J2 Harness listed. Can someone point me in the right direction?
#2 Posted : Monday, May 11, 2009 5:36:57 PM(UTC)
The model number you posted does not come up. Verify and repost it.
prichardh
#3 Posted : Monday, May 11, 2009 5:41:35 PM(UTC)
prichardh
SVE47600W is the correct model #
#4 Posted : Tuesday, May 12, 2009 6:00:48 AM(UTC)
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010191.pdf
J2 refers to a connector on the board
Could be it just needs cleaning.
Be sure to remove power from the unit when doing this
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
prichardh
#5 Posted : Tuesday, May 12, 2009 8:06:04 AM(UTC)
prichardh
I will give this a try and report back. Thanks so much for the info.
prichardh
#6 Posted : Wednesday, May 13, 2009 6:50:42 PM(UTC)
prichardh
THANKS! Cleaning it did the trick.
Guest (4)
