Set timer to "60 minutes" in timed mode and hit the start button. Motor runs and heater coil functions. After 10 minutes the timer has not advanced. Is there an other switch in series with the start switch or is it likely a bad timer? What color is the power wire to the timer? What color is the return wire? Thanks Edwin
Groups: Expert
Cannot find parts manual for the EQ versions to be able to find wiring diagram part number. Timer motor may be 120vac or 240vac, depends on exact model and there are 15 different versions of this dryer. Check inside control panel for wiring diagram. What is the part number on the diagram?
Eric
